down into the grove of the pulley. The deep part of the "V" will contact the bottom of the pulley and not allow the sides of the belt to make contact with the sides of the pulley with enough force to keep it from slipping. Try a belt that doesn't have a deep "V" and one that is notched. The combination might work better for you because it sounds like you are not getting enough friction between the belt and the pulley.
