Tension
One thought that comes to mind is that you are possibly putting too much tension on the halyard. With the extrusion holding the luff straight there isn't the need to over stretch the luff, or grind the Hell out of the halyard with a winch. Excess tension will overload any set of bearings and you don't need the strains required with hank on sails.
