My usual method is to fully raise the sail with the tack free. Then I use a lashing on the tack to pull it down till the wrinkle goes away. After a couple sails I may adjust the tension if needed. This is with a 40 foot luff and I don't need the winch. All I go for is a smooth surface when the sail is in use.
