If you use a snubber
In Response To: Your math is wrong.. ()
If you shackle a snubber to the bobstay fitting you're at the water line and can have much better scope. We oten do and I have it on a snatch block so can let go when we need to. Or just let the snubber run free and pick it up as the chain hook comes aboard.
Go Slow
Sail Far
Stay Long
