XYZ says that too..
Also with an anchor like the XYZ (I have one) the shorter scope seems to work better then the longer scopes. If you have too long a scope and a wind shift, when the anchor comes out and needs to reset you ende up dragging it sideways! Counter intuitive but on shorter scopes it holds a ton!
Go Slow
Sail Far'
Stay Long
