Thanks Brian, I had not intended for the outlets...
In Response To: GFCI... ()
to protect against overloads... I was looking for the GFCI feature... I know it is also available in certain circuit breakers... but retrofitting those breakers to some older panels may be difficult.
You are quite right about the "down stream" aspect of the GFCI outlets, of which I had momentarily forgotten... good point, may save me some labor.
