I would epoxy and glass mat over a
piece of wood and screw to it. This way because I try to look ahead to the time that charger, or what ever, is going to fail. The next replacement item will, most likely, not have the same bolt pattern and you will end up with a boat looking like Swiss cheese over time. A thick enough board of good quality and large enough screws should hold it just fine. As usual, just MHO.
