If you do that to...
In Response To: I use Weld-Mount SS Studs ()
a fiberglass surface be sure to de-wax and roughen it first, if painted, remove the paint and de-wax/roughen.
If you do that to a plywood surface remember that the plys are not glued as strong as the weld mount is glued to the first ply. the first ply could easily break away under load.
