Return to Index
Read Responses
Downwind Marine has it...
In Response To:
I use Weld-Mount SS Studs
I used that system to mount the noise blocking foam stuff on the inside of my engine cover.
Best way to "mount stuff" in the boat?
I would epoxy and glass mat over a
Excellent points Steve.
Sheet metal screws...
An idea I use
lazerette? I don't think that's the best place for it.
Batteries are in the lazerette...
Whenever I think of a lazerette
I agree with Dan on this ...
That would be optimal
If it aint broke don't fix it.
Ventilation & Dryness -- while being heat averse
waterproof...
Well, then just give it breathing room?
How Neat!!! :^)
Didn't find it on Hamilton but sailboatowners.com has it
so does Jamestown Distributors
btw, it IS at Hamilton Marine. Just checked their site.
If you do that to...
Bolting is always stronger that screws
Yeah, I am thinking of a combination setup.
