The best way to join is RF cable is with connectors
In Response To: These are all good suggestions ()
There will be some loss through the connectors but you will likely have more with a splice. If there is an impedance mis-match some of the signal will reflect back. Connectors will have good impedance matching, a splice might match the impedance of the cable but likely won't.
