the kind of spray head you'd want for a shower would be different (and more water saving) than what you'd want for a wash-down. You'd also place a premium on a high-volume pump for a wash-down vs. water-saving for showers. The FA-407 shown here is what I'm using for the wash-down. It produces a very good solid stream that stays in column and is good for punching through blobs of mud -- important because usually you're spraying upwind when you raise the anchor. http://wildfire-equipment.com/eng/products/cordova/cordova.php?p=9
