Return to Index
Read Responses
I just ordered this Jabsco.
In Response To:
I did this with my washdown system...
I'll let you all know how it works out.
Jabsco PAR-Max 7gpm 12V Kit
Coil washdown Hose
The shorter ones work okay-- the longer ones can be a challenge.
I'm using the 15ft Hosecoil Side Mount Enclosure
That is what we had on TPIII, worked fine!
speaking of washdowns... how about a seawater/freshwater system...
Kind of a neat idea, but you would want different nozzles
Aren't the pumps all demand pumps?
We have raw and fresh water -- both at the galley and anchor washdown
That's the thing I was wondering... the sanitary and maintence issues...
I don't currently have a wash down system...
I used to do that on prior boats
My wash down system uses Y valves as well but
A diaphragm type pump would be better for that than a spinning impeller design
Add a wand
I'll second the wand. And please do let us know how it works..
