Return to Index
Read Responses
Interesting...the charts in my HDS-5 are spot on for the areas around here in Maine
In Response To:
Here's another example
I will check those areas you show out tomorrow when I am on the boat.
Crappy charts in the Lowrance HDS-7
In most places they're good
They 'GotYa!'
The built-in Garmin Blue Charts are really good
I have an old Garmin with only the world chart.
I do not unstand this
Mexico Gold Coast? The new Gold charts should be correct
yes it Isabella, I will try the upgrade, Thanks
Garmin said we had 10 feet of water yesterday, then I heard the rumble below from the rising centerboard.
Are you referring to the area NE of the docks?
The area to the north off Spruce Island.
I have one of those early warning systems also
aka Auxiliary Depth Sounder... Precisely
Thank god that linkage is no more, my nerves couldn't take it Charlie.
When Gene Barnes surveyed our Sabre, he suggested not using the CB as a depth sounder.
