The 25mm doesn't shoot as high as it use to and the 12 gauge at first glance appears better then before. The 25mm parachute isn't available anymore.
When we did our test the 25mm parachute flare was almost as good as the SOLAS parachute we sent up. Now they don't make it? Need to do some more research or,,, just stick to my SOLAS parachute ones. The 25mm parachute flares were a little weird putting them into the gun as they were twice as long as the barrel.
