and the appropriate tubes and tools to suction out the bottom of the tank every spring. His notes indicate that the drill pump hose should be pushed around the bottom of the tank through the vent hole until it comes out clean. He further stated that you'll suck out about a gallon of fuel before it that happens.
Seemed to work for him.......
