Am I right in thinking that all you
would need is the flow meters and a 12 volt buzzer, switch, fuse and wire to set up an alarm for the engine and generator? It seems like it would be pretty simple. You could get real spiffy and set up an XY relay so that the engine would shut down when the alarm sounded. All driven by the flow meter. I might try that for my generator. It would react faster then the built in shut down.
