Return to Index
Read Responses
How does the access cover get water on it?
In Response To:
Problem solved.
The "original"
I finished installing the Filter Bosses. They pump water great.
5 gallons of water, whoa!
I'm with Tom on this
I wouldn't use the bilge -- I'd use a bucket
There's no way that amount of water is from condensation...
BTW, where did you last take on fuel...?
agree- you have a leak
I agree, you have a leak. I would
Dave, here are my tanks prior to installation
Is there a Home Depot or Lowes or hardware store nearby?
Problem solved.
Glad to hear it was that simple, Dave!
Yes! Good, let's get this show on the road Dave.
glad it worked out...
That's because I'm not a whiney jerk.
how to start an argument
Sorry John, I don't see it that way.
I like that Dave...
Dave, you are right....
makes sense...best of luck
When the idiot skipper turns off the bilge pump.
I didn't realize that the access plates for the tanks were below the floor boards...
