Return to Index
Read Responses
It is easier to drop the rudder IF you have a travel lift...
In Response To:
That would restrict access to use a puller too
You need to raise the boat about 6' to drop the rudder, or dig a deep hole.
How often do you pull your prop?
Do you have shaft zinc on the shaft(s)
I have a Max Prop ... I pull it every year ...
That's a pretty personal question, don't cha think?
Mine has been on the shaft since 1987
Is that a full keel boat?
Yes full keel with the prop in an aperture...
Our prop...
What kind of puller do you use?
