I believe you Dale. Now, if you use 30 amps a day in Panama and make all the ice cubes you need for the next day overnight I'd be really impressed.
Our system isn't very efficient because when you open the door all the cold goes out the door. We use close to 100 amps a day for the refer. No problem though, the generator only needs to run 1.5 hr a day and that's OK as we run the air conditioner during that time to dry the boat and keep us cool.
