The CG regs say that you need the heat shield if it is...
in the engine space (i.e., you need the 500MA). If it is outside the engine space you don't need the heat shield and can use a 500FP. It is also not allowed to fit a heat shield to a 500FP. Your insurance company will certainly want the heat shield if it is in the engine space.
