Return to Index
Read Responses
Thanks Todd
In Response To:
The CG regs say that you need the heat shield if it is...
Racor 500 - is it necessary to buy heat shield?
Thanks Todd
I thought the requirement
The actual USCG requirement may be for commercial vessels, but insurance companies tensd to apply those requirements to
With insurance companie you never know
All the Racors on our three boats were the conventional ones without "heat shields" (all were in the engine compartment)
The heat shield requirement is relatively recent as I understand it...
Yes, our current boat has 13 seasons under here keel.
I recall seeing that...
Question, What is the heat shield for?
Helps protect the 'plastic parts' from melting during a fire.
RThanks, So that explain why fuel filter is mounted........
