Return to Index
Read Responses
That is a good idea, might be all you need.
In Response To:
Thanks Paul, good idea
Refinishing a teak & holly floor
If there is no finish on it, I'd just give it a light sanding Max.
Thanks Tom
I'm told Waterlox is pretty good
I would give it a good cleaning with TSP before sanding.
Mine had multiple coats of varnish so I used a heat gun to peal them off
That's when a heat gun shines, very thick coats of varnish.
Yes, the heat gun is a good tool
