ANL's...
ANL fuses are actually quite slow in their trip time delay and will support about 150% more than their rating for 500 seconds +/-. The fuse is there to protect the wire so if the wires amapacity can handle it you can go with a bigger ANL..Fusing winches is tough as the stall loads are high and often. What size is your wire feeding the winch?
