Return to Index
Read Responses
His phone 860 822 8756
In Response To:
Neil -- I've got just the guy - he's a marine electric master
Help please on starters
Budda gave me good service in the past
Check the battery and all secondary connections to the starter
IF you can borrow a "hot shot" portable starter
Will do
In this case the ohm's resistance will be the indicator
My idea is to measure voltage drop from
The only way to check the voltage drop...
Careful if you're cranking without starting the engine
Thanks Brian on the load. That is my
Could check for bearing wear causing excessive friction....
