Battery terminal to starter terminal, and also on the negative side
How much drop is acceptabe or normal?
If drop is high, then go step by step along the path.
Yesterday, nothing got hot, after about 5 minutes cranking over a 30 minute period.
Starter warmed to just below my finger temperature. Nothing else felt warm at all
What resistance is acceptable? I suspect my digital meter will show zero or close to that.
