1/2 CTS vs 15mm
In Response To: 15mm pipe ()
The tubes are quite different - 1/2 CTS is about 16mm OD. The fittings are also different sizes - the 1/2 CTS has a white collar, while the collar on the 15mm is gray. SeaTech should make an adapter fitting to go from one to the other, but I haven't checked their website.
