Dan-
What do you mean by wrap the pipe in rubber? I follow the repair by using the larger reinforced tubing with 2 hose clamps, but I don't get why wrap it? btw, how do you get the reinforced tubing to the pin hole leak? Do you have to actually cut the copper pipe first?
Thanks! I have pin holes here in the NE as well !
Rodd L.
