Mine is the same and has never been a problem.
It's just an off the shelf ss fitting with an O-ring. As long as the O-ring is intact it works fine. Never seen any evidence of water in the Racor filter bowl. Of course you tend to be sailing in much more serious conditions than our limited coastal cruising. If you really want to raise the fitting it would be a fairly simple matter to make something with resin thickened with Cabosil or colloidal silica.
