Peter, the PVC idea of a cover was along the lines of what I was considering. That said, as you and others have noted, I'm probably being more distrustful of the deck fitting than I need to be. I'll probably lube the O ring as Brian suggests and not worry about it.
Thank you for the suggestions.
Max
