Return to Index
Read Responses
screeching usually means belt slipping
In Response To:
Thanks,,,I'll check the voltage and the harness.
Tachometer help needed
I had a recent tach problem...
Have you checked the system voltage when indicated RPMs drop?
Your right,,,, what if?
How old is your belt and sheave?
Could be bearings on the alternator too?
Cruiser Jim nailed it.
Ah, the old belt tightening solution. Hope it works in Euro economy as well....
Yeah, the best kind of boat fix - free!
