Return to Index
Read Responses
Ah, the old belt tightening solution. Hope it works in Euro economy as well....
In Response To:
Cruiser Jim nailed it.
Tachometer help needed
I had a recent tach problem...
Have you checked the system voltage when indicated RPMs drop?
Thanks,,,I'll check the voltage and the harness.
screeching usually means belt slipping
Your right,,,, what if?
How old is your belt and sheave?
Could be bearings on the alternator too?
Yeah, the best kind of boat fix - free!
