Return to Index
Read Responses
Could be bearings on the alternator too?
In Response To:
How old is your belt and sheave?
Checking the actual output during the "cycle" would be informative.
Tachometer help needed
I had a recent tach problem...
Have you checked the system voltage when indicated RPMs drop?
Thanks,,,I'll check the voltage and the harness.
screeching usually means belt slipping
Your right,,,, what if?
Cruiser Jim nailed it.
Ah, the old belt tightening solution. Hope it works in Euro economy as well....
Yeah, the best kind of boat fix - free!
