Because the cover for the pump faces inwards, against the engine, and I figured any advantage to Speedseal is lost by having to unbolt the pump to access the cover. Thinking about it further, the Speedseal would probably make it easier, and the large diameter bolt heads look like they might provide a better overall seal holding the cover onto the pump body. Thanks Greg, I'll give the Speedseal folks a call next week.
