Thru hulls
Have you checked that you are actually getting water through the thru hull and hose up to the strainer. I have seen thru hulls blocked by barnacles and all kinds of debris. I have also had grass pack in the hose before the strainer. Simply take the hose off the strainer, hold it below the water line and open the thru hull seacock.
