Return to Index
Read Responses
Nice setup
In Response To:
Panels in down position
I may do something that's a hybrid between your design and Paul's.
Thanks (both of you) for posting.
Rail-mounted Solar Panels
Nice design Max.
I have a single panel
Nice setup
Nice set up Max - I'm looking at doing the same.
You see this offten in Baja
Away from photos will post another config next wk
Wiring?
Hi Peter
Similar system
Peter, check out the "Scanstrut Standard Junction Box"
Thanks all. Max, I'll be in touch.
Removable panels....
