One More idea to reduce the amount of holes in our boat
In Response To: Thru hull Question ()
The current thru hull for the electric bilge pump heads aft around the engine and exits near the stern. The pump is located under the galley double sink. I plan to abandon the old thru hull and tie the pump into the 1 1/2" line for the sink discharge. The sink is near midships and I have never seen it take in seawater and the sink drains would act as a siphon break
