Return to Index
Read Responses
That could get a little wet if you have a robust thru-hull?
In Response To:
One More idea to reduce the amount of holes in our boat
Tom, what is this fixation with thru-hulls?
Thru hull Question
Just my opinion....
That's what I do
I feed the salt water for my "Marine Elagance"
Simplify and reduce the number of holes in my boat
The bildge pump exit is normally above the waterline for reasons including that it gives you an indication of pumping
And using the sink drain thru-hull, it means leaving that seacock open when you leave the boat.
Good point Tom
Is it above the heeled waterline?
Hi Brian
Possible siphoning...
DO you have a siphon break that you will maintain from the bilge pump line?
Ah. Then I'd do it too.
The issue is the sink position relative to heeled waterline?
I have a T just below the drain on my sink.
I wouldn't do it
