The issue is the sink position relative to heeled waterline?
In Response To: Ah. Then I'd do it too. ()
While the configuration of the discharge can exacerbate that if you induce pressure (or conversely reduce pressure) as the boat surges along.
THe plug might work, as long as NOTHING ELSE is concected to it. The checkvalve would make the sink a bit balky. CERTAINLY that would speak against connecting the bilge pump into this drain, in my opinion.
