I would disable....
the temp compensation. If this is an "atmospheric" temp sensor even more reason to disconnect. Temp sensing is important but more so for batteries above 80F than for cold batteries.. Some controllers allow you to turn this off and others don't.. Unless a controller has the ability to add an external temp sensor they can be problematic depending upon location.
