Return to Index
Read Responses
It's a Morningstar Sunsaver MPPT with external temp sensor
In Response To:
I would disable....
Question about charge voltage
14.94v sounds pretty high to me, certainly way too high for float voltage
Ok for acceptance, too high for float.
Is there any chance the "Equalize" button is pushed in?
I thought of equalize too
YOU Should NOT Have an automatic equalizer function?
It seem high, how the fluid level that would tell
I would disable....
Good....
Here's a link to the manual
Problem....
Will follow your advice, thanks
As others, following Miles, said: THAT's too high for a float.
