If you have lead-acid batteries, I like the greater protection on the terminal connector
In Response To: Battery cable end sealing ()
I think the gel cells and AGM batteries seem to have either less acid contact or outgassing corrosion than the conventional lead acid batteries.
As for the cable ends themselves, I doubt there is that much difference.
