is suppose to carry the current better but we just used plane old axle grease I would order in 5 gallon pales. It was good for 3 or 4 hundred amps at 220 thousand volts so I figure a battery cable would do just fine. Any axle bearing grease would do but I use marine grade because I have it on board for my windless bearings.
