I need the inspiration....
The refit goes on..... and on.
Redoing the old reefer compartment. Took out the old reefer. One GOOD point, the old spray in insulation I had between the "super insulation" and the sides of the compartment was hard to chip out, BUT, once out, it was VERY easy to sand away what remained stuck to the walls. I then did a paint cover over it all. Oil based!
Next goes in some insulation along the hull side, a shelf, then an Engel refrigerator box.
