Return to Index
Read Responses
with 22.5kw you could light a small town
In Response To:
True. I have two generators, a 7 1/2 KW and a 15.
Why so much? Are both needed? Or is the second for redundancy?
Out of the shed today
What's that hole in the main hull?
yup. It's my cheater at the dock.
Bus heater means running the engine.
I had one of those on my last boat
Had the Espar, Dickinson wall mount, and Wallas stove/heater
No different than a car heater
Doesn't that catalytic add a lot of humidity?...
Yes it adds humidity but not an issue for us
My trawler has three reverse cycle A/C units.
If you have a genset is makes sense
The small generator would be used at anchor when running the TV.
Dave, how would 6 months away from docks compare in costs on Driftaway?
Well, where we live now is easy to figure.
That would cost even more
My boat's 12V system already uses little power.
The Espar's (or other similar systems') heating discharges are low
I spent one winter living aboard in Stamford, CT.
