Return to Index
Read Responses
House and windlass are, SSB is a new addition
In Response To:
Are all the lines run indvidually with separate lugs to the battery?
Adding a fuse at the battery
If you have two batteries joined in one bank (in parallel), then run it directly to a different terminal.
How big is your windlass?
Max, I have a breaker on my Windlass. Cheers, John
Unprotected lengths
To clarify, I am adding fuses within 7" of the battery for all 3 circuits
Look at the blow curve for the ANL vs the circuit breaker
