Unprotected lengths
ABYC has definate limits on the 'unprotected' lengths. I think the ANL should be within 2' of the battery. Also, the 15' to the 30A and 100A for the SSB seems very excessive. Keep in mind that a fuse will only protect the downstream wiring. With a long run like that, the cables should be sized by the ANL, not the fuses!
