If you have two batteries joined in one bank (in parallel), then run it directly to a different terminal.
The load on the SSB isn't that great (compared to the windlass or engine starters, for example).
Though you probably know this, make sure the terminals are clean -- with AGM or Gel Cells, those are usually not an issue, but on lead cells, if you aren't careful with filling the water...
