Return to Index
Read Responses
Well that's a better sign than not.
In Response To:
Push the button and the light goes on but
Is you email the same, Dan?
I used your old one. Give me a call or email back.
Question on Link 2000 replacement.
Can you find a replacement on eBay?
Mine needed a power off reboot every now and then...
Give some of the guys in Annapolis a call
Link replacement
I may have found the problem,,,, connection
It may not be wired "parallel"
Those connectors are a breeze to put on...
Make sure
Don't replace it - clean it....
Found it's only a 4 wire telephone cable.
Good point on this type of connector...
