After about 18 months, mine failed in closed position.
On my Alberg 35 "Invincible Summer" the solenoid began leaking by. With the valve closed, gas continued to flow to burners until I closed the tank valve. Xintex replaced it for free. Interesting note: The solenoids that Xintex was using in the '90s and maybe beyond were labeled as "gasoline valves" for automotive use only.
