Return to Index
Read Responses
Seems like a good idea. Can you give me specs or
In Response To:
We have an flow alarm on the engine raw water supply
a source?
Hoy many $$
Thanks
Question on exhaust gas temperature
You could always test it...
Check with the operational instructions
I have neve actually measured...
Too many variables/
If the engine pumpe plenty seawater into the exhaust, then
The btu's exchanged with the raw water and the change in the temperature and flow varies
I have a 15 year-old Aqualarm panel
This may be late, but
Eddie, I have done the exact same thing and ...
From the thermodynamics and relative water and exhaust volumes
I think what you said..
That seems about right
